Is oil killing our cars? Part 2
77_MG_Midget
By: Keith Ansell, Foreign Parts Positively, Inc.
Last month's report on this subject is turning out to be just the tip o the iceberg! Many publications have had this subject of zinc-dialkyl- dithiophosphate (ZDDP) covered in varying depths over the last few months. Some publications have even had conflicting stories when you compare one month's article with their next month's article! They are all ending up supporting our report. I have had the good fortune to have the ear of quite a few leaders in the industry including some wonderful input from Castrol and Redline. We have been very reluctant to "dump" Castrol, as it has been such a great supporter of our cars and industry over the years. Castrol hasn't really abandoned our cars, just shifted to a more mass marketing mode. Many Castrol products are not appropriate for our cars today, some still are.
Now for the latest report:
#1 Castrol GTX 20W-50 is still good for our cars after break-in! 10W-40, 10W-30 and other grades are NOT good. Absolute NOT GOOD for any oil (Any Brand) that is marked "Energy Conserving" in the API "Donut" on the bottle, these oils are so low with ZDDP or other additives that they will destroy our cams. Virtually all "Diesel" rated oils are acceptable. (See third article to amend this!)
#2 Castrol HD 30 is a very good oil for break-in of new motors. This oil has one of the largest concentrations of ZDDP and Moly to conserve our cams and tappets. (SEE THIRD ARTICLE.This oil is NOT now recommended by Castrol)
#3 Only an unusual Castrol Syntec 20W-50 approaches the levels of protection we need when we look to the better synthetic lubricants. We are attempting to get this oil but will be using Redline 10W-40 or10W-30 as these are lighter weights for better performance, flow volume, less drag and has the additive package we need.
#4 The trend today is to lighter weight oils to decrease drag, which increases mileage. Most of these seem to be the "Energy Conservation" oils that we cannot use.
#5 Redline oil and others are suggesting a 3,000-mile break-in for new
engines! Proper seating of rings, with today's lubricants is taking that long to properly seal. Shifting to synthetics before that time will just burn a lot of oil and not run as well as hoped.
#6 The "Energy Conservation" trend was first lead by automakers to increase mileage numbers and secondly because the ZDDP and other chemicals degrade the catalytic converter after extended miles, increasing pollution. We don't have catalytic converters and the mileage gains are not that significant for most of us. For you science buffs: ZDDP is a single polar molecule that is attracted to Iron based metals. The one polar end tends to "Stand" the molecule up on the metal surface that it is bonded to by heat and friction. This forms a sacrificial layer to protect the base metal of the cam and tappet from contacting each other. Only at very high pressures on a flat tappet cam is this necessary because the oil is squeezed/wiped from the surface. This high pressure is also present on the gudgeon pin (wrist pin) in diesel engines, therefore the need for ZDDP in all diesel engines. Second part of the equation is Molybdenum disulfide (Moly). The moly bonds to the zinc adding an additional, very slippery, sacrificial layer to the metal. I found out that too much of the moly will create problems; lack of this material reduces the effectiveness of the ZDDP. The percentage, by weight is from .01 to .02%, not much, but necessary. We'll keep you apprised of any new findings! Happy motoring for now!
