As you have already been told a dwell meter is a valuable addition to any owner who performs repairs/tuneup on their vehicles.
As it has been brought up that if the condensor is not doing its job and the points start transferring metal, becoming pitted, a dwell meter will give you a more precise measurement, or if someone forgets to lube the rubbing block on the points and they wear prematurely and adjustment is needed more frequently, then a meter is a good tool to have.
A good dwell meter will also have a degree of needle sensitivity and if you watch your needle reading bouncing 4% or more then it's letting you know that the shaft bushings are in need of attention.
Almost all professional(and a lot of hobbyist) auto meters(multimeters) will include a dwell meter along with ohm, volt, amp and often farad testing.... So shop the meter manufacturers content.
Even the timing lights are getting into the act with some of the newer(less than 10 years old) timing lights are including dwell readings... So if you already have an ohm/voltmeter and need a dwell meter, you might be able to combine that with the purchase of a timing light. I know AutZone/Checkers, out here in Hawaii has a timing light with dwell meter that sold for just over 130 a couple of years ago.
