Hi
Just joined the forum after buying a 79 Spit. It was in excellent shape confirmed when I tore out the old interior and could have a look inside the wheel wells etc...no rust whatsoever. The paint is great and I am having the seats redone at a local North Bay shop. I only have one problem that so far. The stereo is a Pioneer CD/radio and the fuse located at the back of the unit itself keeps blowing. Electrics are not my thing but here is what I did.
1. took the radio out and noticed that the ground was not connected to anything.
2. There are two wires under the dash that look like the ground should plug into. One is a double black wire into a plug the other is a red wire with white spiralled around it. Again two wires into a plug.
3. Tried every combination but still blows the fuse.
4. Finally I held the ground from the radio against bare metal and it worked for about 2 seconds before blowing. The ground was not held on the bare metal very well and just holding it with my fingers.
5. Gave up after an hour and decided to join a forum or take it to the garage to get it fixed.
By the way the map light doesn't work either and went down at the same time the radio stopped working.
Anyone in North Bay?
Ted A
Ted A
