nevets
Took the Healey out for a spin and experienced some engine sputtering. It started once the engine got fully warmed up, and not under load (as in climbing a hill). It would sputter when stepping on the gas after coming off a downgrade (fourth gear, foot off the accelerator). Car would sputter, like it was starved for gas, nearly die, then it would clear up and all would be well.
I’m thinking it’s possibly dirty carburetor float valves? Maybe a dirty fuel filter? A few years back I replaced the float valves with Gross Jets (due to overflowing fuel issue).
Any thoughts/suggestions will be appreciated.
Hi Guest!
No not necessarily a defective coil as has been mentioned will cause the engine to behave this way. Similarly, and a more prevalent failure is a faulty condenser in the conventional point type ignition system.---Fwiw--Keoke
----Keoke- :thumbsup:
