Matthew E. Herd
Gentlemen,
I have observed the following phenomenon concerning my '76 Midget. I blew the head gasket in ?October? autocrossing (won that day, though!). The gasket burned through between cyl. 1 and 2. Turns out one of the guides needed replacing, the head needed a skim cut, and valve seals needed to be installed.
At any rate, I reinstalled the head (after it sat a good while) and fired it up a few weeks ago. I posted about having a problem with two head studs at the time of install. Since then I may have run the engine 6 or so times, driving perhaps 50 miles in total. Power definitely seemed to improve, and the smoking on startup went completely away (no more oil past the guides).
However, I previously sealed my cooling system because the pressure reservoir didn't fit with the custom airbox. However, the pressure that I saw recently seemed to build to the point where it'd come out of the seams, so I installed an inline filler neck/pressure cap. The fluid would bleed off a bit as it expanded, then reach a steady state (with some air in the system). However, I still had trouble with coolant leaks. I tightened every hose clamp, etc, and still the coolant would leak. Finally, while driving the car, it started to overheat. It had overheated the first time I took it out (highly unusual for this car), and it had no coolant in the system. At the time, I thought nothing of it and filled it up again. When it started to get hot the second time, I just figured too much coolant had bled out past the cap. However, as I drove it the remaining 7 miles home, it was leaking again (coolant was getting onto my windshield, which is how I knew it was leaking). It was also overheating again, within only 15 minutes and 7 miles or so.
While I still wasn't able to find the source of the leak (last week) I could hear hissing that sounded like it came from either the driver's side radiator hose (at the radiator) or the radiator endcap itself. I started to investigate today, and found that the coolant was halfway up the hose after having sat for a week. The car had overheated, but no coolant leaked from the hose or the radiator beyond a certain level. So, I opted to fill the system with water and let it idle (pressure cap off). I could see that the system took an enormous amount of water.
I ran the engine, and saw a bit of oil residue in the water (very slight). I assumed that this was from the filler neck, which was oiled from the manufacturer. However, another thing I noticed was that the water level dropped slightly as the car ran. Once the thermostat opened, the level may have dropped slightly faster. Finally, I heard a sound that was not unlike sheet metal flexing as wind hit it. Since I was inside a pole barn constructed primarily of corrugated sheet metal, I thought it was just the wind. However, then I heard it again (definitely from the engine) and immediately shut the engine off.
At this point, I decided to do a compression test, as I figured something was wrong. I worked on getting the alternator belt off (always a pain) and got all 4 plugs out. As I worked, I noticed that the coolant level dropped. I removed the valve cover and, sure enough, there was white foam all over the cover. I also checked the dipstick and that was foamy too. However, after I performed the compression test, I found that the readings were:
Cyl 1: 236
Cyl 2: 240
Cyl 3: 235
Cyl 4: 232
I plan on re-testing, in case coolant improved the seal somehow (if it's in the cylinders) once it has the opportunity to leak out. However, I suspect those numbers are genuine. I am trying not to skew the outcome of potential opinions, but I realized in retrospect that the static level of coolant is probably approximately at the level of the head/block interface.
As an aside, I noticed that when the vehicle started to overheat (or at least get much warmer than it's usual position, well left of "N", it never really overheated terminally) it would stumble on application of throttle (possibly a rich condition). This could simply be indicative of increased intake manifold temperature (and therefore the requirement for a leaner mix).
Let me know thoughts on this one. I just got done refurbishing the head after blowing the gasket, so the replacement was brand new, and everything looked to be in good order as I put it all together.
Cyl 1: 236
Cyl 2: 240
Cyl 3: 235
Cyl 4: 232
