LastDeadLast
Board,
I have a neat little problem with my horn... It works great, when ignition isn't on. For example; with the key off, I press the horn button, "BEEP". I insert the key, press the horn button, "BEEP". I turn the ignition key to any setting, press the horn button, "....", nothing. I turn the key back to off, press the horn button, "....", again nothing. I take the key out, press the horn button, "BEEP".
I've checked the horn relay, everything seems ok. I can jump it at any time and get it to work. Under the dash, I've grounded the wire after it comes out of the steering column and again I can make the horn go "BEEP". I've taken the steering wheel off and veryified that the switch works... funny thing is: it almost seems that the steering column "looses it's ground" when the key is turned if that makes sense.
Any ideas?
Thanks in advance,
Any ideas?
Thanks in advance,
