Intake manifold water pipe repair...
Dennis
Hi folks,
First try at posting so here goes. I'm doing some winter restoration on my 74 spit. The intake manifold water pipes are in need of some repair. What is the best way to go about doing this? Or should I just start looking for a replacement manifold, I have HS2's currently installed but will be putting in some HS4's I picked up.
Thanks,
Dennis
I dont see why the old pipe could not be drilled out and a replacement fitted with the propper epoxy.Stainless pipe would be the trick.
MD(mad dog)
I hadn't even considered that, it's a great idea! I have one old intake for my ZS laying around that I replaced for the same reason. I'll use it to experiment with.
Thanks!
Dennis
