wkilleffer
Ok, we had a pretty balmy day here today, with a high temperature around 65deg and blue skies all around. I decided to use the B as a work car, and am glad I was able.
The problem is that in the heat of the day, it seemed to be having issues with boiling fuel.
The engine's an 18GK and the carbs are HS4s. A little over a year ago, I replaced the long-gone asbestos insulation on the back of the heat shield with some mylar-fronted underhood insulation fabric. It made a good difference in the heat level around the carbs.
Maybe that's not perfect, but I'm inclined to think the fuel line that runs at the back of the engine compartment could be the culprit now.
Thanks to tips received in a recent post, I seem to have the car running more or less the way it should, or at least acceptably.
The issue would sometimes crop up when stopped at a light. The idle speed would slowly drop down and idle would start to feel rough. Once we were moving, everything seemed just fine. The worst of it would come after the engine had been stopped for a short time, like five or 10 minutes. Then, the car would be hard to start. Once started, it was hard to keep running. If we came to a stop and I wasn't quick about it, the engine would end up stalling.
Is there a way to insulate that fuel line to make this less of an issue? I use 93 octane if that matters.
Thank you,
-Bill
Thank you,
-Bill
