RickB
I bought two rolls of Frost King duct insulation at Lowes.
It's got 1/8" dense foam on one side and fairly thick metal (foil) on the other.
The foam side is adhesive.
This stuff comes in 12" x 15' rolls and costs about $18 per roll at Lowe's.
I pulled out the seats, the shifter, the console hung from a bungee from the rear view.
All the old carpet came out.
Cleaned up the area a bit.
Then I started putting the stuff in. It was pretty easy, went smoothly.
Got the engine side of the footwells done, behind the pedals and the floor area all covered.
Same for the other side.
Covered the tunnel and both floors under the seats. The vertical area behind the seats. Then I had just enough to put a run across the rear deck.
Then I put the "new" carpet kit in and bolted the seats down.
I am hoping this stuff cuts down on heat and road noise like Dynamat. Time will tell.
So - those areas I described equal 30 square feet.
Hi Guest!
