Ed_K
Hello all,
I thought replacing the 8 sway arm bushings with new prothane bushings would only take 30 minutes or so.
... Wait, this is an Austin Healey. What was I thinking ?
Is there a trick ( certain order ) to reinstalling the
rebushed bolts back into the holes in the spring pans ?
I have been jacking up under the spring pans and can almost get the nuts started on each end ... but not both ends
The anti sway bars are not mentioned in the shop manual or the Bentley manual. I may get lucky if I keep jacking up by the spring pans and then put another jack under the sway bar ends.
Any suggestions to make this easier or do I just need to keep thrashing away as is usually the case with a new to me Healey repair task ?
Any suggestions to make this easier would be appreciated .
Thanks,
Ed
Thanks,
Ed
