bigjones
Yo!
For various reasons, I'm yanking the mechanical pump (this is a 1500) and installing an Airtex E8016S electric.
Hey!! It's made here in the USA - I'm stupified!!
Top of pic shows what is included.
Bottom shows fuse and relay I plan to add.
I really want to do this correctly.
OK, I suppose they both go in the Positive lead to the pump but in what order and as close to the pump as possible?
I've found a convenient spade on the original fuse box that gives juice when the ignition is on so I can run a lead from there I'm thinking. Do I then split this lead into two, at the fuel pump, for the relay, or run two leads from the fuse box?
This wire(s) will run under the carpet, etc. Do I need to wrap the wire in some sort of protective tape?
The rating for this pump is 1 amp so I bought some 3 amp fuses - the leaflet says use a 10 amp fuse - what gives?
If I remember right, the fuel line from the tank takes an inverted "U" shape and then under the car. I"m going to install the pump as low down as poss on the first leg, right?
Tubing in the kit is 5/16" - is this going to give me bother? Isn't our stuff 1/4" ID?
Those clips I don't like - I'll use proper "radiator" /Jubilee clips.
I have already installed an electric (Mr. Gasket) under the hood. I'm going to use that to pump out all the gas from the tank beforehand. I was toying with the idea of then filling the tank with hot soapy water and running that through, followed by a gallon ethyl alcohol (from Lowes), or is that unnecessary?
Advice much appreciated!
Cheers!
Cheers!
Hi Guest!
