RobT
Being a compulsive fiddler (on the TR that is) and always looking for ways to improve the Lucas electricals on my car, it strikes me that there is quite a bit of wiring under the dash that is not protected by any fuses. In particular the circuts to the ignition switch, light switch and ammeter are unfused. This seems like not such a good idea - grounding one of these circuits would be a real problem and could cause a lot of under-dash smoking, if not a fire!
So I am considering installing a main breaker or fuse (or fuses) to protect the circuits up-stream of the fuse box. At the ammeter and/or off the starter solenoid would be the logical places to install such a device.
Has anyone else had this idea too, or experience doing something similar? A switchable circuit breaker would be best, you could also use it to isolate the electricals during repairs, etc. I am thinking 50A should do the trick. Does that sound about right to folks?
Again, thanks in advance.
Rob.
Rob.
