Indication of posts read v unread
Crankshaft
I use the forum on 3 devices but only shows I have read a post. The other two I must change the page I'm reading or log out & return to see the "unread" indication removed.
Is there a setting I can change to correct this?
Most likely it is a cache issue where the "unread" page indicator is still cached in your other devices.
