kcbugeye1275
In my last BE restoration my bodyman buddy, Mike, suggested that after we got the hood properly adjusted to drill holes in the hinges through the suporting material under the hinges before taking the bonnet off so that when you reinstall, you can get some bolts in the hinges, then position the hinges by setting the bits back into the holes and simply tighten the bolts. Your bonnet should be properly positioned on the hinges. Sadly, we had to pull the engine out of another friends BE, John, last night, but before taking the hinges off. we did drill the hinges. In a week or two, we'll be putting it back together, and this step should make things easier.
