HI
When I got the car, it did not come with keys, the PO just used a small screwdriver. That's what I had been doing. The other day while working on the heater, I noticed that the fan would would come on when the switch was operated even with the ignition switch in the off position. So I was checking into that I notice the center was depressed and I messed with it and it popped out. Now a screwdriver won't turn it. Looks like I need a key, to be inserted and then pushed in and turned.
Is this correct?
What lock should I use to get a number off of? Is the drivers door the same as the ignition?
Will most key smiths be able to make some kind of a key?
Any information would be appreciated.
Thanks
Is this correct?
Thanks
Hi Guest!
