mdionne
Member
I have searched for the answer but can't find it. Can someone tell me how to remove the ignition switch assembly from the steering column of a 79 midget? I have removed the steering wheel and plastic covers over the turn signals and wipers. I have taken out the four bolts that hold the column to the body. I see the two headless bolts. Now what? Will I need to remove the entire column? How do you remove those bolts?
I am removing it because I am replacing the whole thing.
Thanks!
Thanks!
