Healey Nut
Ok so Im trying to get this 64 BJ8 running , fresh engine rebuild .
#1 piston TDC #6 cylinder valves rocking ,rotor arm pointing at #1 cylinder, timing mark on crank pulley bang on . Removed the dizzy cap and did the voltage test to the LT wire points open 12volts to ground points closed 0 volts .
Got fuel tried to start she fires shots of flame out the exhaust but she just wont pick up .
So I decide Im going to try a fresh set of plugs , picked them up gapped them installed them ....now Ive go no spark ...nothing not a peep .
Ignition on 13 volts to the coil coil gets warm to the touch . HT lead direct from coil outlet to ground , crank er over no spark . tried the coil out of my running 67 , same result Aaaaaaaaaahhhhhhh .
Voltage test ignition on 13 volts to coil . LT wire on side of dizzy 0 volts point closed ..0 volts points open
Any ideas ??? Pulled all my hair out and gave up before I lost it . Heeeeeellllp
Hi Guest!
:wink-new:
