Andre the Giant
Some of you may remember (or still might be trying to forget) my '79 Midget carburation problem, which eventually was diagnosed as an ignition problem. The symptoms were that the vehicle idled fine but when gas was applied, the car acted like it was getting no fuel. That problem was fixed when I did the following.
The car has a CEI Distributor, (not OPUS) and I replaced the plugs, wires, dist cap, rotor, and coil (with a Lucas Sport coil.) I gapped the plugs a little wider than called for. Now the engine won't start at all. The engine spins, the wire from the coil spits out rapid blue sparks when held against the engine block, the plug wires do the same. I've checked the carb to make sure it's getting fuel.
I'm thinking I may need to gap the plugs back down a little. I may have gone too far. Any other ideas?
Thanks,
Andy
Thanks,
Andy
