jaegzie
Ok, I finally got a chance to sit and work on the BE.
My BE cosists of the following first off:
59: BE
63: Wiring harness
69: 1275CC.
It is negative ground.
There are really two parts to this question.
First, what is the least I need to hook up as far as wiring to get the car to run. Currently, I have the ignition switch hooked up to the switch box(I forgot what it is called) then down to the starter. Also I have the wires running to the coil and to the dizzy.
When I use the key the car will fire and start to run, but as soon as i stop turning the key, the engine dies immediately. Any suggestions, could this be because the wiring is not fully installed?
I guess I am stuck at this point.
TIA
59: BE
63: Wiring harness
69: 1275CC.
TIA
