Hi I been reading alot of posts about (BTDC) before top dead center and (ATDC) aftertop dead center .When you are standing in front of the car everything to the left of the pointer is BTDC and to the right is ATDC. I have my 73 TR 16 degrees ATDC sound righr?
If the carbs are 73 versions, it may well be the carbs' float chamber vent valve..They were particularly troublesome in 73 where by they would not always open when the engine was idling thereby causing stalling problems.
Only by increasing the rpms and thereby transitioning to the "open throttle" position was the float chamber able to ventillate properly.
The very next year, 1974, the transition was redesigned to a more reliable configuration and remained that way until the end.
If your carb has exactly this type of vent valve, it's a 73 and subject to problems.
