Ignition service time need recommendations
CarCrazed
Hey guys,
I need to once again pool this mass of knowledge and get some recommendations. I have a bad miss caused by a bad plug wire. I have read about the hard plastic black connectors that are the usual culprit and I have them /ubbthreads/images/graemlins/frown.gif I also understand the Lucas side exit original caps may no longer be available?? At any rate I need sources and recommendations for cap, wires, spark plug connectors, points, condenser and rotor. I really just want to go through it all. I also read about relocating the coil, I won't do mine at the moment I am fairly certain its good. Any other ideas welcome. Thanks again guys
Hi Check the archives there has been considerable discussion on this subject.
There are some side entry caps offered on E-bay at the moment they will be quite pricy though, additionally you might give some consideration to shedding the points and up grading to an electronic Pertronix kit.
Regarding your Signature; You can always slide in side ways holler-in: "Holly Cow What a Ride"----Keoke- /ubbthreads/images/graemlins/jester.gif
