young MG enthusiast
I'm a senior at the University of Wisconsin, Madison and I recently purchased a 1976 MGB... without really knowing what I was getting myself into. After many hours spent under the hood, learning about the quirks of MGs, I've really come to appreciate it when it actually works. I'm loving every minute of my MG experience.
Now for the question:
I'm having problems getting my MGB started. Last fall, the last time I was out for the season, I did a really dumb thing. I let my roommate drive. We pulled over, I let him jump in to drive for a while. He started the car, and it was making an awful noise. I should have stopped him right away, but he pulled out onto the road, and we didn't have a safe place to pull back over for a couple minutes. Beads of sweat running down my face, I opened the hood, and all of a sudden it dawned on my roommate to check the key... it was stuck in the "start" position. Yeah, that's right... the starter was running the whole time (about 3 or 4 minutes total). I drove it home and parked it for the winter.......
Well, I knew the starter had to be checked, so I took it off, and sure enough, it was shot. The flywheel teeth are okay thankfully. I had the starter rebuilt and put it in last week. Still, the car wouldn't even try to turn over. Today, I was working on it, and I noticed a very pungent electrical smell coming from around the electronic ignition and ignition coil when I tried to start it. It turns out the ballast resistor is heating up, and heating up quickly.
I fear that I burned something else out when the starter continued to run. If anyone has any ideas about what I should check next, I would really appreciate them. I know you can burn the iginition coil if it continues produce the spark needed for starting... but would this cause the ballast resistor to heat up?
Thanks to all who read this.
[ 03-06-2004: Message edited by: young MG enthusiast ]</p>
