I got the engine in the herald to run earlier last week, but I have some ignition problems
It was running, but missing fairly well, but missing on a frequent basis. Since the distributor shaft was wobbly, I got a hold of a different dizzy, with a much better shaft/ bearing, cleaned it up, put in new points/condenser etc. then I couldn't get it to run at all. Eventually, I figured out that the drive dog was on the opposite direction vs. the original dizzy so I swapped around all the cables, and now it at least sputters.
The plugs were somewhat wet from cranking the engine and black from having run way to rich earlier on, could this really be enough to cause sparking problems? Other than swapping the coil is there anyway to tell if it is generating enough voltage?
