ron wilson
you folks have b een a great help in getting my 74 B together. so I have another question for all.
The ignition lite will not come on when I turn the key on. Have checked the bulb and it is ok and ther wiring also seems ok as if I pull the bulb out still in the socket and hook a ground wire to the socket the lite will come on but when I start the engine with this arrangement the lite will not go out. I have installed a voltmeter it reads about 12 1/2 volts at idle and 13 1/2 at 2000 rpm.
