capitalcitycars
Well Guys, the saga continues. When we last left off, Jeff road to the rescue and fixed a few problems and taught this young buck a few things. Well, here I am for another lesson.
As you know, I have Jeff's loaner installed temp till my rebuilt dizzy arrives. I took it out tonight for a serious drive. Besides figuring out that the gas guage was off by an 1/8 of a tank, another problem popped up. The car idles fine, compression is good, plugs are not fouled, carb adjusted right, adjusted the points to specs, put newer plug wires on, the wiring is mostly correct thanks to Jeff pointing out I was using the wrong wiring diagram which is the last time I take a Hayes manual seriously. Now, going from a standing start to 1st, then 2nd gear, the car does what it's suppose to due. As the load and sustained higher rpms increase the engine starts jerking, I loose power, and I feather the pedal till I'm safely off the road.
Now, I suspect since Jeff's dizzy is a vacuum advance and my car is set up for a non vacuum advance dizzy, this is the cause of my problem since no hose is running from the dizzy to the carb. The connection on my carb I plugged. The solution would be to hook up the hose from the vac advance to the carb till my non vac advance dizzy arrives. Am I on the right track or should I be looking elsewhere. Thanks! /ubbthreads/images/graemlins/crazy.gif
