TRDejaVu said:I like Firefox and have used it for a long time, but every now and again it locks up; it just happened again today. You exit the program and then try to restart it and it tells you that an instance of FF is already running and you need to reboot. Looking on the Mozilla website, they say that the Zone Alarm firewall might be one cause and that you should uninstall it and go back to the Windows firewall - I DON'T THINK SO. I will not use IE for its security holes, so this is very frustrating. Perhaps Mozilla should just take responsibility and fix FF.
I use Zone Alarm because of its strength compared to the windows firewall. I have not had any other issues with it. I am not prepared to downgrade on security because Mozilla can't get it right with FF.DNK said:Ian- Had the same problem with FF and Zone. Got rid of the zone . No problem any more.
TRDejaVu said:You exit the program and then try to restart it and it tells you that an instance of FF is already running and you need to reboot.
Doesn't work. Nor can I shutdown FF using a separate process manager program that I use. This is a known FF problem that Mozilla seem unable to fix.jsneddon said:TRDejaVu said:You exit the program and then try to restart it and it tells you that an instance of FF is already running and you need to reboot.
happens every once in a while to me. You probably don't need to reboot - go into task manager (right-click on an empty part of the system tray and click Task Manager), click on Processes and you'll find one clearly marked "Firefox" - just kill that process and try starting FF again.
Win98 stopped being supported with security updates years ago.AweMan said:{ I use win98 se and F.F. exclusivly}
That's OK, nobody writes 16bit virus' anymore either.TRDejaVu said:Win98 stopped being supported with security updates years ago.
