EWD
Morning folks:
re: 74 TR6
Have an unusual problem with choke and idling. Car starts fine with choke out. When it warms up and choke is in, it will either idle steady at about 1400 rpm or it will idle down to a stall. If the car is in the mood to idle down, I have to keep the choke about 1/2 way out to keep the idle higher. On any given day, I don't know which way it's going to go. Oil is in the carbs, gas is fresh, and otherwise, the engine is running fine.
Any advice is certainly appreciated.
Thanks,
Will
re: 74 TR6
Thanks,
Will
Hi Guest!
