Idle Issues
mlapage
I own a 1980 TR8 convert. w/ZS's. Awhile back the car overheated. About 1 1/2 mos. ago I had the water pump replaced. After I picked up the car I started having cold starting issues-hard to start; idled at 200-300 rpm's and at cold start, engine would bough down and almost die when pulling away from stand still. I just had the starter replaced. The engine still has the before mentioned problems.
When warm the idle is still around 200-300 rpm's, but runs normal otherwise.
Questios:
1. When replacing the water pump, do you need to remove the timing cover/belt?
2. If not timing belt related, what would be my next place to look?
If this has been discussed, would someone point me in the correct direction, in order to read the pertanent posts?
Have you got all the air out of the cooling system? The ZS's used on the TR8s have water chokes and if they are getting more air than coolant flowing through the bodies on the carbs they could be effecting the carburettor chokes and not letting them work correctly.
If not that, then I would double check the timing as it was probably distrubed while replacing the water pump.
