healeyboz
Car is running great, however,......
I am getting a noise from the clutch every once in awhile.
I speculate that it is the throw out bearing. It has happened when the clutch pedal is pressed in and it has happened when the clutch pedal is not pressed in. The sound goes away when the oppisite is done. (Does that make sense?)
It has happened three times while out for a drive. Probably out of about 30 times. It will continue until the car is parked and restarted the next day.
Thoughts as to what is happening?
