Jim_Gruber
I discovered a fuel leak when I tried to start Bugsy IV this
AM and this afternoon replaced the rubber ethanol proof, yeah right, fuel line and changed the inline filter by the carb. An SU is back mounted on the wheel Well if front of tire. This was a new SU that I installed. Cranked a bit and Bugsy fired right up. Revved trying to get him warmed up and played with choke. Things got worse and worse and kept getting rougher and rougher. Finally with no power Bugsy just quit.
Bummer! So I noticed rusty sediment in the clear fuel filter. That's not good. Next question will be is there sediment in the tank and has it plugged things up. no time to deal with it anymore today but I want to resolve ASAP. so should next steps be.
1) Drain tank?
2) Do SU's have a built in filter, I don't think so
3) Take tops off of carbs and see if there is sediment in the bowls.
Tank looked pretty shiny and clean when I dropped it and shown a flashlight in the tank. Tank had been drained and car had been stored with a dry tank.
Need recommendations on next steps.
1) Drain tank?
