Stewart
I think I'm going to be sick ....engine noise exp
Engine's making an intermittent expensive sounding noise. Does not do it when cold and has been intermittent when warm but is becoming more frequent. Only does it between 700 and 1k rpm. Oil pressure is still great at a needle width above the 75 mark hot at cruise and half way between 50 and 75 at hot idle. I've pulled the plugs wires one by one and there is no noticeable change in the noise. I have not seen any metal in the oil as of yet though the filter may be catching it. Oil was clean at the last oil change 500 miles ago.
Q0-ELRI" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
