So the '63 I just got was running ok enough to get it home, but was running really and everything under the hood is a disaster. Allison ignition, alternator, and a wiring mess. But it ran. The carbs are 1968 and not correct for this car and are all cobbled together with wire and ties...argh... Take a look at the manifold. What the heck's going on there? It seems that when something went bad, patch it as best as can be patched with whatever is lying around. Anyway, Holes in manifold plugged, I have a set of AUD52 that I glass beaded in and out and are sparking clean.
Here are the troubles. I think one of my jets is out of center. The one carb. Piston drops with a nice "plunk" but the other does not and will not pull up easily. I'm assuming the jet is not centered but want to know if there are other things that might be wrong. It seems that when I drop the piston, it gets stuck in the down position.
The other issue is that gas it draining out of the overflow if the rear carb. Not sure why it is doing this. I checked the gap - .125" - and it's fine. the needle and seat are spotless without any varnish at all on them.
Lastly, the rear jet is leaking, but it is leaking where it enters the float bowl. The o-ring is not the best and moss does not sell a new one. Has anybody found an off the shelf o-ring that I can use? I had a decent one for the front carb, tightened it up and its perfect. I just don't have the couple bucks now to get new jets. The car desperately needs tires and that is what I am saving for.
I have a period Genny, and coil, new wires, plugs and a re-built dizzy so I should be in good running shape once the carb issues are resolved.
