Reading an article directly from Valvoline, there seems to be a misconception about V-R1 being high in ZDDP. Valvoline states that V-R1 meets todays specifications for modern vehicles and has a limited amount of ZDDP in it. To get a high percentage of ZDDP, you must use their conventional Racing oil, which is not the same. The conventional racing oils are not recommended for street vehicles as they don't meet governmental standards for catalytic converters. They are designed for, among other things, flat tappet engines with higher valve spring pressures, as in racing engines and cam protection. It's expensive, but I just thought I'd throw that out there. PJ
