Just like Nunyas, I 'gone an' done it'; I let some smoke out of my wires. I was pulling into my driveway and noticed some smoke coming out of my shifter (!). I immediately cut the motor, disconnected the battery and removed the shifter knob.
I saw the cause almost immediately: the two wires that connected to the OD shifter switch, particularly the red one, looked like a dog had chewed them up. If that wasn't an accident waiting to happen...thankfully, the only things damaged were a couple of wires and a melted bullet connector.
My opinion is that the flexing of the wires when I shifted caused the bare part of the wiring to rub against the shifter itself, thereby causing a short to ground. Thankfully, I'm only out a few bits of wire and a bullet connector, instead of a gearbox harness or a whole car.
Would you believe that tomorrow's project was to fuse the OD and fuel pump circuits? /ubbthreads/images/graemlins/tongue.gif
Maybe this was the car's way of telling me to do it, or else...
