So,
following my earlier post which said I had a noise which came from below the tranny tunnel I took out the gearbox. Lo and behold the shiny bit (technical term that) in the middle of the clutch cover was loose and rattling in the "triangular finger like bits" which hold it.Great fun this , hope it drives when it's all back together! While I'm at it I thought there was some play in the clutch fork bit and have bought some new bushes and taper pin and plastic washers. Is this an easy job? How hard do you wack it to get the taper pin out?
