Randy Harris
I attacked the fuel smell early this morning. Inspected the filler neck for leaks - none. Fuel sender area - seems ok, no leaks, but does have fuel odor. The Armacord cover is heavy with smell of gas. You can actually see where the gas has soaked into it over many years, long before I owned her.
I wiped down the tank and Voila! The left front top of the tank, about 3 square inches, has been repaired by a PO. Lousy repair too. It looks at first blush like Bondo. It is dark gray in color, not metallic like JB Weld. I sand it down flat to get a better look. Sure enough, a microscopic amount of fuel appears from a crack in the repair, so small I cannot locate its precise location. I sand some more and one other micro leak appears. I wipe them down and as I watch they slowly start to wet the tank again. We're talking an area of 1/8" in diameter But the leak stops before it puddles and then appears to evaporate.
My hypothesis is that these leaks have been present for years. I never noticed because I rarely fill up with gas and they present on the top of the tank, so they rarely if ever get wet. With the top down (100% of the time), the vapor smells disappear before reaching my nose.
Can I do a temporary repair with JB Weld and then proceed to repair or replace the tank soon? Is this a sensible solution? I've got a full tank of gas right now and don't know how to remove it while it's full. The sender unit gasket should be replaced either way as well. Is there a better product to use for a temporary leak repair?
Advice?
Thanks
Randy
Advice?
Thanks
Randy
Hi Guest!
