Nunyas
Wow... when it rains it pours. Last night I adjusted the valves on my B, changed the distributor cap, and replaced the rotor. After putting it all back together, I started the engine to see if I could notice any differences. First thing I noticed was the valve train is certainly alot less noisy. I also looked at the timing, it seems to be set a little too far advanced. I noticed that it seemed 'rock steady' at 1500 RPMs, but at 1000 RPMs it jumped up and down between 10 BTC and 15 BTC. After a few minutes, I noticed that the water temp got extremely 'hot' while it was idling with the temp guage pointing straight at HOT. I rev'ed the engine up to 2k RPM for a little and it forced air through the radiator (belt driven fan) and the temp came down. Out of curiousity, I looked under the car to peak at how the exhaust is doing. I noticed that from the catalytic converter to the front of the first muffler was all glowing red (this was at night so I don't know if I would have seen the glow during the day). After noticing this, the car eventually started to run really erratic and finally stalled. Once it stalled, the car would not start until I had let it set for a couple of hours to let everything cool down.
Fast foward to 3PM today, I get in my car to leave work. Start the engine easy enough, but then it stalls. Ok. I restart the engine, got it running relatively ok, and leave the parking lot. I got 3 blocks from the office and I notice smoke. I pull to the side of the road to figure out where this is all coming from. I look under the car, nothing smoking down there. While standing outside I notice the smoke is INSIDE the passenger cabin. So, I looked for the source, and found that the smoke was coming from the floor board directly over the muffler. The car would not restart after several minutes, and is currently parked on the side of the road.
I seem to recall hearing on these boards that an overly rich fuel mixture can cause the cat to glow red. However, the "metering needle" is set at 6 flats (1 turn) from full lean condition, and the air mixture nut and screw are set at their "middle" of adjustment setting. Spark plugs 1, 2, and 4 are light gray. While spark plug 3 is a dark golden brown. If anything, it seems to me that I should be running "lean".
When I had the car at the muffler shop the guy doing the work pointed out to me that my exhaust manifold was begining to 'crystalize' on its under side. I haven't noticed anything that sounds like an exhaust leak under the hood yet, but I guess it's still possible.
So, there's my plight for the day. I have a carb rebuild kit at home, and plan to rebuild it this weekend. Is the carb probable cause for my symptoms? or do I have some other deep seated issues that I really need to investigate too? Mind you I am still having some problems with electricals as noted in the other thread "electricals... grrrr"
