During this past winter, on a bitterly cold day, my '80 TR-7 Spider lost a wheel bearing on the drivers front side. I limped about 1/10 mile and had the car towed to a shop. The spindle was scored up a bit; you could see a lip had been built up near the entry point and there were two small grooves , about 1/4" each. A new bearing and race were installed. The car had some shimmy at 50 MPH that would go away once you passed 60 mph. Otherwise, it seemed ok.
Yesterday, I noticed the tire had been worn badly on the inner side. When I rocked the wheel, I was dismayed at the amount of wobble. So I disaasembled the wheel, removed the bearing, found nice clear grease, cleaned off the spindle, and tried to file down the scoring. The bearing, about 3 months old, was gritty so I put in another new bearing. When I went to press in a new race, I found that it would not seat firmly in the hub. In fact, the old one had probably been spinning in the hub.
A mechanic friend recommended bearing retaining glue and gave me some to use. The wheel spun smoothly on the spindle at rest. When I drove the car the shimmy was the same at teh same speed and there's still a little wobble at rest [actually it's the same on the right and left front spindle].
Questions: Has anyone used the bearing glue? Should there be a small amount of movement at the wheel, or none? Do I need to find a replacement hub and spindle?
Thanks in advance!
Jeff
Thanks in advance!
Jeff
