Https
Administrator
Boss
This took a while to get working right, but I have converted the site to use https (256 bit encrypted) connections instead of the standard insecure http URL. You should see a little lock in the address bar when you're browsing the site. When you post a message you may not see the lock because the editor uses AJAX, but if you click in the address bar it should still say https.
This is something I've been meaning to do for some time. Let me know if you run into any problems.
Thanks, Bas - that little extra bit of security is appreciated!
