TR4/4A HS6 carbs in tr4
spbvmb
Member
I am needing new carbs in my '64 TR4 and noticed that HS6 type sell for about half the price of H6 which the car has now. What's the advise form all you experienced folks out there on making the switch. Thanks, Phil
Hello Phil,
the HS series is more modern but will give similar performance. You will probably need to budget for the different throttle and choke linkages plus some modification to your throttle and choke operation.
I would think that it is a reasonable modification and that only purists would notice the change, if you are not too concerned about originality.
Alec
Hello again Phil,
just a slight thought, why do you need to replace the H6's, they rarely wear bad enough to warrant replacement.
Alec
Hi Phil,
As a side note, your car is was likely built before '64, if it came with H6 carbs (TRs were registered in the year actually sold, not the year of manufacture).
Triumph used H6s for the first couple years of TR4 produciotin, then began using Zenith Stromberg of their own manufacture. Perhaps an economy move, but also probably in protest of the close relationship between SU and their main competitor. A couple years later Triumph returned to using SUs, this time the HS6 you mention, on TR4A.
The HS6 are shorter-bodied carbs (S=Short), usually fitted to longer manifolds. It's a good setup. I'd personally want to match the H6 to the short TR manifold or the HS6 to the long TR manifold, and not mix them up. There might be some other minor fitting issues, but I'm sure they could be swapped this way, as a set.
To best preserve the value of your car, have you considered getting those carbs rebuilt? Might cost less, too.
I don't think there were any really big improvements to the HS6, over the H6. At least not enough to make a significant difference in performance.
There are several companies rebuilding SUs in the US, and SU parts are being produced again (I believe primarily by Burlen Industries in the UK). Apple Hydraulics is one company doing rebuilds, that I've heard good things about. Their website is https://www.applehydraulics.com/carbs.htm
I'm sure some others are rebuilding them, and you might do some googling to see what you can find.
However, if you do decide to get newer carbs for your car and want to sell off your old SUs, let me know. I might be interested. My TR4 came with a set of Hitachi SUs from a Datsun 240Z!
Cheers!
Alan Myers
San Jose, Calif.
'62 TR4 CT17602L
[ QUOTE ]
Triumph used H6s for the first couple years of TR4 produciotin, then began using Zenith Stromberg of their own manufacture. Perhaps an economy move, but also probably in protest of the close relationship between SU and their main competitor. A couple years later Triumph returned to using SUs, this time the HS6 you mention, on TR4A....
[/ QUOTE ]
Right. It was Standard-Triumph's own Dennis Barbet who was largely responsible for the design of the "beloved" /ubbthreads/images/graemlins/smile.gif Zenith-Stromberg carburetors, and it was mostly in response to the fact that SU at the time was owned by then-competitor BMC, who wanted to charge Triumph a whole bunch more for SUs. But there's more to that story than we'll likely ever know. There were small (CD-125) Strombergs roughly equivalent to the HS2s found on a Spitfire, but Triumph kept using the SUs on the Spits until Federal emission regulations led them to the single-Stromberg setup of the late Mk3 and all later "Federal" Spitfires!
Meanwhile, HS6s could be considered a bit simpler (whether they're "better" or not, I couldn't say). But one of the "issues" during Triumph's development of the Strombergs was that they be pretty much interchangeable with the SUs with no discernible difference in performance.
