Dougal
Hi All
Had a bit of difficulty last night under the car(nothing new here). I was installing new steering side rods with Nylock nuts as apposed to castlated ones with split pins.
The crossrod was not on so the siderods went on easily. However when I started to do up the nut, the balljoint itself just started turning. The friction of the Nylock was greater than the friction in the balljoint.
This must be a common problem, i tried pulling down on the side rod jacking the car up and down to get some more force on the joints to with no joy.
My solution was to grind a slot in the end of each thread. I put the nut on finger tight and then heald the bolt(and balljoint still with a screwdriver in my new slot. Using this method I was able to tighten the nut.
Question is there a simpler way of doing this?? I have new tierod ends to install and would prefer not to have to grind slots in them if possible.
Cheers
Dougal
Cheers
Dougal
Hi Guest!
