AUSMHLY
64 BJ8. Original starter. Every once in a while when starting the car, cold or warm, the starter will turn over once then stop. Try again, turns over once, maybe twice then stops. Try again, then maybe it starts or have to do it again. But always starts within 3-4 tries. It starts within one or two cranks. Never just turns over and over, etc till it starts. Cars starts immediately, first or second crank almost all of the time.
Yesterday, different situation. Car was cold, started first crank. Drove it to a restaurant, 15minutes. Three hours after dinner, started right up. Drove it to a friends house, 15min. Parked it, turned key off. Noticed I parked to close to another car. Turn key cranked once didn't start. Tried again, will not turn over. Just click sound. Tried 3 times, would not turn over. 3 hours later, turned the key started right up. Turn it off, tried again, started right up, drove home. This morning, turned the key, started right up. I put the trickle charger on the battery to find out how charged up it is. 15 minutes later showed it was fully charged.
The battery seems fine. Why does the starter sometimes act like it's not going to start the car? It seems like the battery isn't providing enough current, but it does. I've checked that all cables are tight to the starter and solenoid. Last nights example of only getting a click, 3 times starter not turning over, then 3 hrs later, starts no problem?
