How to remove entire dash panel on BN6?
Chet Zerlin
Hi all,
On my BN6 the FO removed the top dash pad and painted both the top and the dash panel rather than cover with vinyl. I'm thinking about redoing all of that back to the "stock" configuration. To do so I obviously have to remove the dash panel. After I've removed all of the switches and gauges how do I remove the dash panel itself? Looking at the diagrams in the Moss catalog there doesn't seem to be anything holding it on other than a center metal strap screwed to the back of the dash and then to the firewall.
It can't be that easy can it? :smile-new:
Any information/instructions are appreciated!
Thanks!
Chet
Easy. A couple of screws at each end, and one in the center of the dash.
With all the devices removed, the only Big Thing is to remove the steering wheel, and trafficator with stator tube.
It's really easy__and I'm not just saying that ;)
If you had a link saved, then it's pabon. You should always be able to find it at spcarsplus.com, as the gallery has been hosted on several different servers over the years (they don't last forever, but as long as the database is backed up, we're good).
