How long is a ah 3000 clutch slave pushrod?
britndablood
Member
I am trying to determine if I have the correct part installed if someone could measure a stock pushrod from the end to the center of the pin hole it would be greatly appriciated.
Thanks,
Casey
Thanks,
Casey
Casey the pushrods are all the same length as are the cylinder housings you have a defective clutch--Fwiw-Keoke
Considering I looked at the release bearing and the fork and the pressure plate today with a bore scope and the PO had a longer push rod in the slave and the PO supplied this push rod I figured that it would be a good idea to check because he also owned a sprite that had 3 differnet push rods over the years. Also considering that the wiring harness looks like a three year old has been playing in the scrap bin and the pinion nut was only on hand tight, I thought it would be a good idea to ask a question before I spent the time pulling out a transmission that did not have a problem in the first place.
Your problem is not with the transmission it is with the clutch assembly. However, if you suspect a push rod from another car has been installed. Why not just obtain the correct one and put it in as as an interim test ---Keoke
