In a recent post, I described a problem I had with my '78 running rich...smoking, sputtering, blackening my plugs, and petro-stink at the tailpipe. I dismantled/rebuilt the carb including the diaphram and verified that the heat mass in the H20 choke was heating up and working properly. Checked out A-OK. I tuned the idle and enrichment and.....still smoking, etc...
This evening I finally took a deep dive into the choke iteself, removing it from the carb, dismantling and cleaning everything. I think I found the culprit.
The last piece I checked was the enrichment pin which, as near as I can tell, should move up and down freely to let additional fuel flow/not flow into the carb. The mechanism seems to work like the valves in a trumpet. But to change notes on this horn, you have to smack the valve with a hammer and pull it back out with pliers!!!
The pin was stuck quite securely in the up (choke on) position and I can't imagine that the tiny rotating parts in the choke have enough gumption to move it. Ah, ha!
Based on an article I was reading, I removed the breather valve from the opposite side of the choke body, inserted a thin hex wrench through the hole down to the needle, and tapped on the top of the enrichment needle. With several light whacks, it did move to the down (choke off) possition. However, only with some force with needle-nose pliers does it return to the choke-on possition. I can't imagine this is how it's supposed to work, so I assume I've found my problem.
The article explains that you can "tap" the needle down and continue tapping until the whole valve assembly comes out. I attempted this procedure so I could clean/lube it so it works properly (i.e., smooth up/down, choke-on/off with movement that is light enough for the small parts in the choke to actuate...I assume). But this guy is stuck!
I can certainly put muscle into it and drive it out, but don't want to damage anything. How much force should I be using here to remove the enrichment valve assembly to remove and/or unstick it....or am I barking up the wrong tree (again!)?
Please help me get back on the road this weekend...the weather should be too nice here to pass up!!!!
