How does the Spitfire accomplish positive crank case ventillation? I have a 78 with a 79 motor I got from a salvage yard and rebuilt. But the only crank case ventillation I could find is the line from the rocker cover to the constant depression side of the carb.
But isn't there supposed to be some sort of crank case ventillation from the lower portion of the crank case? If so, where is it or how it it accomplished? I can't find any lines from the lower crank case that look like ventillation lines. (Like on the MGB for example).
Anyone know how or if crank case ventillation is done on the Spitfire?
