Legal Bill said:
Mine is brand new and not shrunk. I have to pull each corner forward to get the clasps to lock. I can;t help but think this is more abut the frame being mounted in the right location, since the bows have trouble clearing the channel area of the the well when I put it down. If those bows fell cleanly into the well, that would greatly reduce the overall effort.
Hi Bill,
The frame has very little adjustment movement front to back, side to side. The mounting plate has 3 holes and they are not much bigger than the bolts that go through them. Maybe 1/8" clearance. If your mounting plate was positioned as far back as it would go, then that's why your having both problems of the back bow pressing against the material when you try to push it down and maybe why the top doesn't reach the clasps. The clasp hook length is adjustable, but that may not solve the final pull to lock it in place.
I'd suggest loosening the two top nuts and the nut on the bottom of the front elevator bolt on each of the mounting plates. Get some help and try and give it a good pull forward to see if you can move it. It may not let you, being the top material is clipped to the rear trim rail and there may not be enough stretch of top material to let you moving it forward.
You may have to remove the screws holding the trim rail to the water channel, so as to remove that rail. If you find you can then move the frame forward a little, then remove the clips that hold the top material to the trim rail, give the material the need length, then re-clip the material back on the trim rail.
That may solve the shortness at the windscreen, being the frame has now moved forward a little.
Another option is to move the windscreen back a little. That may involve moving the side windows back too. Which may affect the clearance around the top and side wood. The top may slacken up a bit too and not be as drum tight. Cause and effect.
Does this shine a light on your situation?
Cheers,
Roger
