Hi Larry,
That bar of yours is identical to the old one that was in my TR4 until recently. I'm replacing it with a more substantial unit, taller and fixed to the floor/frame, to comply with racing rules, provide greater safety and give increased chassis rigidity.
But, I'm *not* suggesting not to install the one you've got there and I gotta slightly disagree with any folks who say "street" roll bars like that one are useless and discourage their use. I think they provide some increased margin of safety, even if it's not a whole lot. Even a "street" bar is more substantial than the hoodsticks!
"Street" bars are sized for height and width to allow the top to be raised and lowered. In order to fit a "properly sized" roll bar, the car would be committed to toplessness. (The taller/wider custom roll cage going into my car will be fitted under a hard top, so this isn't a concern.)
Even with a "street" bar, you might find that raising and lowering the convertible top is just a little trickier. I did.
Just don't panic if the hoodsticks don't quite clear the roll bar in the usual relaxed or de-tensioned position. The "trick" to raising is to lift the hoodsticks behind the bar, because they might not quite clear until tensioned with the lever at the b-post. If this is the case, temporarily tensioning them until the two forward sticks are postioned ahead of the bar does the trick. Then just release the tension until the top is secured all the way around. Once the top is fastened, tension it as usual. Really it's only a minor, extra step that becomes second nature after a while.
Back to your question, though. My bar was installed over the carpet (previous owner). I would definitely not do it that way again. In my opinion, the ideal would be to remove the carpet and have it properly cut and trimmed to fit nicely around the base of the roll bar. Maybe some hook and loop fastening (Velcro) or snap fasteners could be used to keep the seam closed around the base of the roll bar. In my opinion that would give the nicest and cleanest look. But, more importantly, it would allow the carpet to be easily removed for cleaning or if it ever gets wet. The latter is of particular concern, because if the car ever gets caught in a rain shower with the top down, or a little water gets inside during it's weekly bath, the carpet under the bar mounts can get wet and might stay soaked a long time, promoting rust. Also, if not carefully sealed, it's possible some splash might find it's way to the carpet, up from below, around the mounting bolt holes.
The heavy mounting plates and bolt heads might make for a pretty lumpy appearance of the carpet, right around the base. A layer of padding under the carpet, much like is used on the floors of our cars, could help that a lot by slightly raising the rest of the carpeted area to be more level with the bolt heads.
I agree strongly with the suggestion to install some padding on the roll bar to protect noggins, and maybe even a head rest type pad on any car where lowback seats are used. Also don't bolt anything to the roll bar, such as a shoulder-style seat belt, anywhere around head height. (I speak from bad personal experience about both these items.)
