I am trying to decide if I need to sell a kidney to get a rear oil seal or not. How much of a leak are we talking. If it sits for a week will all the oil drain out? Does it just leak a little after driving. Does it leak enough that when driven oil will cover the underside of the car? Is there potential for the clutch disk to get oil on it?
Just trying to feel out the importance of this piece and if it is worth financial stress...
Hi Guest!
So, what PCV valve did you use (and is it rigged between the oil separator and the intake manifold - and what sort of carb setup are you using)? Was it just trial and error? I guess I'm wondering if I can fool with restricting the vacuum to the pancake PCV valve (in my dual HS2 carb set-up).
