The way I addressed the infamus heat issue with my Healey;
1- During restoration build up in the engine bay ensure that all panels around the foot wells and bulkhead are completely sealed with seamsealer.
2- Before spending any $ on Layers of dynamat products I first took a flood light placed it in the engine bay turn it on and got into the cockpit and looked for any sighn of light comming through, if so it must be sealed off.
Most of the problems of heat comming into the cockpit is from old or missing rubber gromets from the bulkhead. Also lots of heat will come through from the corners of the bulkhead where the winshield pillars sit that area is likely to have a space anywhere from 1/4" to 3/8", for some reason the shroud does not sit very flat on top of the bulkhead, heat will rise and finds it's way into the cockpit of the car.
Make sure that the transmission cover is also sealed well.
I don't have Dynamat in my car, all I have is the jute padding and carpet and it is very comfortable when driving in hot days stuck in trafic.
Roger
